Основи програмування
Re: Основи програмування
Повідомлення GorbachenkoVasyl » 11 листопада 2010, 21:09
Сорри, не получилось сделать... ибо физика подвела...
Повідомлення Василь » 25 листопада 2010, 12:55
буду по чучуть вылаживать...
using System;
using System.Collections.Generic;
using System.Text;
namespace _6_solution
    class Program
        static PiratesHold piratesHold = new PiratesHold();
        static void Main(string[] args)
            piratesHold.loadBarrels(10, Material.wood, Freight.rum);
            piratesHold.loadBarrels(5, Material.wood, Freight.water);
            piratesHold.loadBarrels(20, Material.iron, Freight.powder);
            piratesHold.loadBattles(100, Freight.rum);
            piratesHold.loadBattles(100, Freight.water);
            double Pbrutto = piratesHold.GetPbrutto();
            double Pnetto = piratesHold.GetPnetto(Freight.rum);
    class PiratesHold
        //List<Vessel> vesselList = new List<Vessel>();
        const int max = 200;
        Barrel[] Barrels = new Barrel[max];
        Bottle[] Bottles = new Bottle[max];
        int N_Barrels = 0;
        int N_Bottles = 0;
        public void loadBarrels(int number, Material material, Freight freight)
            int rndInit = (int)(DateTime.Now.Ticks);
            Random Rnd = new Random(rndInit);
            for (int N = 0; N < number; N++)
                double H = 0.5 + Rnd.NextDouble() / 2;
                double R = 0.2 + Rnd.NextDouble() / 20;
                double d = 0.02 + Rnd.NextDouble() / 100;
                if (material == Material.iron) d = 0.001;
                // vesselList.Add(new Barrel(H, R, d, material, freight));
                if (N_Barrels + 2 < max) Barrels[N_Barrels++] = new Barrel(H, R, d, material, freight); // !!!
        public void loadBattles(int number, Freight freight)
                double R = 0.05 + Rnd.NextDouble() / 50;
                double d = 0.005 + Rnd.NextDouble() / 300;
                //  vesselList.Add(new Bottle (R,d, freight));
                if (N_Bottles + 2 < max) Bottles[N_Bottles++] = new Bottle(R, d, freight);  //  !!!
        public double GetPbrutto()
            double Pbrutto = 0;
 *          foreach (Barrel X in Barrels)
                if (X != null) Pbrutto += X.Pbrutto();  //  !!!
            foreach (Bottle X in Bottles)
            return Pbrutto;
        public double GetPnetto(Freight freight)
            double Pnetto = 0;
                if (X != null) Pnetto += X.Pnetto(freight);  //  !!!
            return Pnetto;
    //++++++++++++++++++ for LAB ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ begin
    //описи типів для п.1.завдання
    enum    Material   {     wood,   iron,   glass   };
    enum    Freight    {      water,  rum,    powder  };
    class Vessel : object
        static double g = 9.81;
        protected double S;                 // площа стінок ємності
        protected double d;                 // товщина стінок
        protected double V;                 // обїем ємності
        protected Material material;        // матеріал ємності
        public Freight freight;             // речовина вмісту ємності
        // 2. Реалізувати методи density, freightDensity,
        // які повертають густину ємності та грузу.
        double density()      // кг/м^3
            return 1/v;
        double freightDensity()      // кг/м^3
    class Barrel : Vessel
    class Bottle : Vessel
    //++++++++++++++++++ for LAB ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ end
  В трюм піратського фрегата завантажено груз (Freight) найважливіших для піратів видів
                water:    1000 кг/м^3;
                rum:      930 кг/м^3;
                powder:   1600 ru/м^3;
 у ємностях двох видів
                Діжка (Barrel)циліндричної форми
                Пляшка (Bottle) сферичної форми
 Матеріали (Material) ємностей
                wood:      690 кг/м^3;  (діжка)
                iron:      7800 кг/м^3; (діжка)
                glass:     2500 кг/м^3; (пляшка)
 1. Реалізувати як перерахування (Enum) свій тип для використання вантажів та матерыалів ємностей.
 2. Реалізувати методи density, freightDensity, які повертають густину ємності та грузу.
 3. Реалізувати у класі Vessel методи для визначення ваги-брутто ємності та ваги-нетто для певної речовини,
    що наповнює ємність. Дав. коментарі-підказки у вигляді " // !!! "
 4. Реалізувати у двох класах, що походять від Vessel (ємність), необхідні для роботи програми конструктори,
Повідомлення Максим Нікітченко » 25 листопада 2010, 12:55
Вася,ти можеш написати друге третє завдання?
Максим Нікітченко
З нами з: 11 листопада 2010, 12:57
Повідомлення Максим Нікітченко » 25 листопада 2010, 12:58
виклади повністю,не можна виділити
Максим Нікітченко
Повідомлення Василь » 25 листопада 2010, 13:06
using System;
using System.Text;
    class Program
    class PiratesHold
        int N_Barrels = 0;
        int N_Bottles = 0;
            double Pbrutto = 0;
            return Pbrutto;
            double Pnetto = 0;
            return Pnetto;
        double density()
        {// кг/м^3
            switch (material)
                case Material.wood  : return 690;
                case Material.iron  : return 7800;
                case Material.glass : return  2500;
            switch (freight)
                case Freight.water: return 1000;
                case Freight.rum: return 930;
                case Freight.powder: return 1600;
                water:    1000 кг/м^3;
                rum:      930 кг/м^3;
Повідомлення Василь » 25 листопада 2010, 13:08
первое и второе задание вот:
        double density()
        {// кг/м^3
            switch (material)
                case Material.wood: return 690;
            switch (freight)
Повідомлення Максим Нікітченко » 25 листопада 2010, 13:11
дякуємо
чекаємо третє
Максим Нікітченко
Повідомлення Василь » 25 листопада 2010, 13:40
Трейтее готово
        double Pnetto()
            return V * density()*g;
        double Pbrutto(Freight x)
            return g * (S * d * freightDensity()  + V * density());
        double density()
        {// кг/м^3
            switch (material)
        {// кг/м^3
            switch (freight)
Повідомлення Максим Нікітченко » 25 листопада 2010, 13:42
дякую
але в нас різні крапаль умови,тобто по різному написано
це палєвно
Максим Нікітченко
Повідомлення Василь » 25 листопада 2010, 13:46
ошибка.... в трейтем
        double Pnetto(Freight x)
            if (x == freight ){
        double Pbrutto()
Повернутись до Семестр 1
Зараз переглядають цей форум: Немає зареєстрованих користувачів і 11 гостей
